The Fuel Filler is fitted to the inside of the cockpit. It is made from the same thing as the fuel tank., A blown plastic melding. I cut the ends to fit. It is bonded into position with Redux at the top around the filler cap making up all the gaps to get a good seal. After Cure straps of bid are placed around the top and bottom to help hold it on place.
