Fitting the instrument panel was a bit of a challenge!!! I had to sand a lot of the top flange away to get a good fit against the inside of the firewall. I decided to do the Europa club mod and to mount it on rubber bushes from the inside. I first created a new flange on the inside of the Instalment panel. I then mounted AN4 bolts to the flange and through the fire wall. The holes in the firewall are drilled out to 10mm and rubber bushes are added either side and then tightened up. This gives a fully rubber bush mounted Instrument panel.
