Construction Of the Europa XS
Date:  3-8-2009
Number of Hours:  6.00
Brief Description:  Well a big moment has finally arrived
Well a big moment has finally arrived. I’m in the final stages of preparing to bong the top and bottom halves of the fuselage together. In preparation the stern post is temporarily fitted. I drilled 1/8th holes for the fixing clecos and screws which are removed after the Redux has set. Final trial fit of the top to bottom and all joints scuff sanded ready
Stern Post Fitting
Stern Post Fitting
Small Bolts or Clecos
Final fit check
Final fit check
