Construction Of the Europa XS
Date:  12-15-2007
Number of Hours:  2.50
Brief Description:  Rear Bulkhead
The rear Bulkhead is cut out from 3mm foam from the template provided. Then two ply’s of bid are laid up on each side, after a 3mm ply wood insert is added for fixing the trim servo later. I covered the while area with peal-ply ready for bonding later.
Ply wood insert
Ply wood insert
