Seat pans are made to cover the valve so that if the valve is in the open position, the seat pans will not fit into their position. When the seat pans are in position the valve cannot be closed or vibrate into the closed position. The seat pans are made in the same way to the Europa chock which gives them good strength and protects the foam.
