Construction Of the Europa XS
Date:  12-9-2007
Number of Hours:  2.25
Brief Description:  Fuel Gauge / Fuel Sender
I decide I would like to fit the Fuel Sender and Fuel Gauge as well as using the original sight gauge. A hole is made in the Port Headrest base to allow the sender probe to be fitted thought the headrest, which also allows maintenance. The only difference to the standard mod is that the hole in the tank for the sender is made more to the centre of the tank. This stops the hole and locking ring been made over the seem in the tank. It also makes the hole in the headrest much neater in the back corner instead of in the middle of the headrest. Again thank you to Pat Tunney www.europaxs.com for his help here as his advice has made a nice job. The sender anf Fuel gauge was obtained from www.wema.co.uk
Under Headrest
Under Headrest
Through Headrest
Through Headrest
Sender and Locking Ring
