I marked out the area for the Pip Pin recess location as described in the manual. As I am going to do a small mod. here, there are a few changes. I have decided to fit a cover cap for the the pip pins. This will give a nice finish later. The cover is made from 32mm solvent weld plumbing pipe, found at your local plumbers merchants. So I have dug out the tailplane into a round hole instead of a square one. although it is exactly the same size. I now layed up the 2 ply's of bid down onto the tube support below. I have added peal ply to the top of the hole, as I will be bonding in the threaded part. I have also layed a ply of bid to the top of the cover for painting later.
