Fitted the second trim tab drive pin with flox to the Port side. All left to cure. Later I will cover with bid as I did with the STBD side. To get the drive pins the same on each tailplane I had to make a jig out of 1/4 bore pipe to fit over the drive pins. It took a little time to get everything good and straight.
