Brief Description: Port Tailplane Layup (Underside)
After Saturdays lay-up of the bottom surface, I took the STBD tailplane out of the jig block and turned it over to prepare for the top surface lay-up. All ready now after sanding the rough edges and feathering the L.E. and the tip to blend with the foam.
