I have now had the center rib inspected and I can now proceed with the Tailplans. I started by joining the Port cores together, this is achieved by simply mixing up some dry micro and pushing the cores together then weight is added to stop them moving apart until they are set. I had to grind away some foam where the rib fits to get a nice joint.
