Construction Of the Europa XS
Date:  1-22-2006
Number of Hours:  5.50
Brief Description:  Tailplane Prep
Finally got started on the tailplane. After opening the protective packaging, I laid out both tailplans on my work bench, fastened together the slots in the underside surfaces with dry micro. The slots are where the foam is cut out for the lightening holes. The sides were first masked with tape then the dry micro added, left now to set in the jig blocks.
