Brief Description: Fitted Aileron Hinge to Port side
Fitted Aileron Hinge to Port side, It is fixed the same way as the rudder. Drilling, Flox and Rivets. Both Ailerons finished, apart from the mass balance arms which will be fitted later after they have been test fitted to the wings to make sure I fit them in the correct position.
