Today I prepared and completed the Port root close out and the STBD tip close out. The tip is just 2 ply's of did at +/- 45o to the cord line. However the root needs is more fidely work. 1 ply of bid first then set out the plate and bolt arrangement for putting in the aileron. This has to be dun on the bench and add it the aileron after it has been wetted out. very fidely but it looks ok and all measurements checked, then left to cure.
