Construction Of the Europa XS
Date:  4-12-2009
Number of Hours:  5.75
Brief Description:  Port door window Pop out
After fitting the windows. I discovered I had the bottom corner of the Port door window Pop out of its rebate. I must have not had it secure enough when the Redux was curing.
What should I do??? After talking to my inspector he says to gently warm the Perspex with an hear drier and gently prise with a thin flat increment like a paint scraper. As I did this it was working OK Until.... SNAP!!! Yes it broke. What Now???
My solution was to repair the corner and to add a door lock. Into the situation. This has worked well after all. I will lock the other side with a small Pip pin from the inside.
Broken Window
Broken Window
Fixed With Door Lock
Inside
Inside
