Just a small job of fitting the Wing stiffer located over the front wing pin entry point on the inside of ether side. A 4" 4mm thick foam is shaped for this. The 4 ply's of "bid" are laid over it and onto the cockpit all around.
Put in Ply's of Bid in the inside of the fire wall and the top of the fuselage.
