Bonding the top trailing edge skin on the wing is a job i have been waiting to get out of the way. After the inspection I proceed in the preparation. The space between the flaps Ailerons and the top skin has to be set. The best thing to use here is some 3mm floor lino. It will allow for enough space for the filler and paint later. The lino is fixed and covered with parcel tape to prevent it sticking together. There is about 4mm to 7mm spaces on the top of the ribs. I got advice from Neville. To get a good fit and to make sure there is no voids under the skin, Put a layer of Redux on the ribs and put the top on with plastic over the Redux.
