Construction Of the Europa XS
Date:  2-15-2009
Number of Hours:  6.75
Brief Description:  Fitting The Baggage Bay
After installing the flap drive. I continued fitting the baggage bay. The front is bonded to the cockpit module and the rib supports are bonded to the fuselage floor, first with Redux then 2 tapes of bid are added. Also 2 tapes of bib to either side of the baggage bay onto the fuselage sides. I also decided to make 2” wide flange around the top of the baggage bay, as I intend to bond the top on and everything together at the same time. The peal ply will be taken off just before bonding.
Splash Mould
Splash Mould
Fitted Flange
Fitted Flange
Supports Bonded
Supports Bonded
