Construction Of the Europa XS
Date:  1-25-2009
Number of Hours:  6.50
Brief Description:  Baggage Bay
I Cut out the “D” panel and fitted it with anchor nut. Also cutting out the access holes in the bottom and made 3mm ply panels. After trimming the outside edge, I fitted it into the fuselage to get a good fit and to measure the height of the support ribs which are bonded to the underside of the baggage bay.
“D” panel
“D” panel
support ribs
support ribs
