Construction Of the Europa XS
Europa XS
Wing Pins
The last thing on setting the wing incidence is to fix in the wing pins with Redux. I saved this until last because I may have had to remove them at some stage. The Rear pin has to be set with the pip pin so the holes line up correctly.
Rear Pip Pin
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
