Construction Of the Europa XS
Europa XS
Fitting the Top
Started some work on the fuselage top. There was a little trimming to make it fit the bottom half.
I progressed to making access panel and an inspection hole in the top half. First splash mouldings are made of the outside surface.
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
