Construction Of the Europa XS
Europa XS
Prepared For Bonding
Finally go to work on the CM and get it ready for bonding into the fuselage. All contact areas are scuff sanded which are in contact with each other. I drew around the CM to get the correct position.
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
