Cutting The Cockpit Module seems like an odd procedure to cut something you buy into pieces. Hols are cut to make it lighter and for bonding it to the fuselage. There are cut lines already on the surface but it is easer to see them if you go over them with a pencil or marker first. Next drill holes in the corners with a hole saw then cut out with a jigsaw.
