Construction Of the Europa XS
Europa XS
Tie Downs
The wing tie downs are fitted into the last wing spar. Prepared for bonding then held in place with Redux and flox mix, to ensure it dose not move befor the “Bid” lay-ups are cured, it has a single rivet to hols it in place.
Stuck in place with Redux
Lay-up Compleat
Under Wing
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
