Construction Of the Europa XS
Date:  7-14-2007
Number of Hours:  3.00
Manual Reference:  Mod 73 part 1
Brief Description:  MANDATORY Mod 73 part 1
This is a MANDATORY mod to strengthen the underside of the tail plane pip pin recess.
Start by measuring the cut out on the underside. Cut out the skin down to the TP6 bush. The hole is now extended outboard to find the inboard side of the outboard rib. Once located, the hole is extended inboard to find the end of the TP6. After location, extend a further 10mm past to expose the T. Tube. The hole is then extended cord wise to a width of 40mm and a feather 10mm and shaped to a radius span wise.
Marking Out
Marking Out
First Cut Through The Skin
Finding the end of the TP6
