Prepared both Ailerons for layup of the bottom skins, cutting off the support block at the T.E. and sanding it down flush. I then removed the peal ply from the T.E. The I put on peal ply at the tip and root also across the L.E. so cutting away the foam later will be better for the closeout of the L.E.
