Started by tidying up the flaps after curing, sanding the edges. Now moved on to making a tip and root gigs for setting up the Flap hinges. It is important to get them both the same. I also fasten in the the spacer in the flap hinges with Lock tight bearing lock compound. All reedy now to start the closeouts.
