I drilled the holes for the pip pins with a little help from a friend to make sure I drilled nice and straight. Pins are drill out with a 1/4 drill. All fits together very nice now.I have to make a drain hole on the underside to let out any water they my get in. I used a silicon tube nosele as this is tapered and will leave a nice small hole on the bottom surface.
