Construction Of the Europa XS
Europa XS
Bushes
Fitted the Bushes in the inboard rib of the tailplans. I had to measure carefully, then drill with a 10mm drill. It is a good idea to trial fit before bonding in the bushes with flox. All fitted good and level at the same and left to cure.
Seting Insedence
Bonding in the bushes
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
