Construction Of the Europa XS
Date:  4-1-2006
Number of Hours:  4.50
Brief Description:  Drive Pin Layup
Got a Through a few jobs today. I first did the three ply's of bid over the STBD trim tab drive pin as I did with the PortI have also made the jig block for carrying the tailplane torque tube, this in ready for setting up of the tailplans on the tube.I filled the reuses in the T.E. of trim tabs to get the level for the flattener strips to be fixed. This has been filled with a dry micro, I will send them smooth when the micro had cured.
Drive Pin Layup
Drive Pin Layup
Dry Micro
Dry Micro
Torque tube Setup
Torque tube Setup
