Added 3 ply's of bid over the trim tab drive pin, this finishes it off. I need now to line the other side up with this one. I started to fit the port trim tab, this is dun the same way as I did with the STBS side, I have fixed the hinges to the trim tab.Thursday 30th. March. 2006Fitted Port trim tab as I did with the STBS trim tab. I also started to prepare for fitting the Port Trim Tab drive pin.
