Started to prepare Rudder hinges for fitting to the L.E. lip. I cut out the slots and sanded out the corners at 45o. Then I fixed the hinges to a straight edge to line them all together, I drilled all the holes and held in place with Clecos. Roughed the hinges to get a good bond when fixed in place with Flox and Rivets.Later this evening, came back and drilled the hinges, bonded in place and all riveted together.
