Construction Of the Europa XS
Europa XS
Some work on the Engine Cowls
Some work on the Engine Cowls, before fixing preparation is needed to open up the vents and the opening for the propeller hub. I also made the hatches for inspection of the Coolant and Oil Levels
Prop Hub Opening
Air Inlet
Hatches for inspection
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
