Construction Of the Europa XS
Europa XS
Some Wiring
I keep adding some wiring along the way. I decided as this is a try gear That If I could get every thing into the tunnel I would. This way it emerges at the back if the Instrument panel thought the ducting.
Behind The Panel
In the Tunnel
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
