Michaels RV-8
RV-8
Horiz. Stabilizer
5-22-2013
Riveting Continues - Rear and Front Spars 3
The completed front spar assembly. The tape covers the holes where the HS-404 and HS-405 ribs are attached in the next step.
The shop side of the rivets look good, I used the blue rivet gauge to check each rivet to make sure they were driven to the correct size.
The Hinge Brackets, HS-411PP and VA-146 hinge bearing gets attached to the rear spar using 4 AN3-5A bolts, AN960-10 washers and AN365-1032 nuts.
RV-8 Home
201
Elevators
Horiz. Stabilizer
How it Started
My Inspiration
Practice Kits
Vertical Stabilizer
Workshop
