I finished the EAA work bench 24x48 and the first of two modified EAA work tables. I expanded the length of the tables to 72" and made the top 1-1/2" thick since I used MDF rather than plywood. I also added a 3/16 hard board top and will add a hardwood trim around the entine table to help save the edges.
The other table is the 24x48 work bench with a drill press I purchased from Harbor Freight. The other end should have a band saw on it soon.
