The one item missing from air compressor system is some type of filter to capture the small partials of dirt and moisture. After a few trips to Harbor Freight and Lowe's I gathered all the supplies and got started. I needed two outlets, one to the reel mounted above to power my hand tools, and the other a line that I can reduce down to my paint gun.
I also started my final work table this Holiday weekend. This will be my main work table once I start my build. The table is the standard EAA design that measures 36" x 73". It will get the same top as the smaller one, two 3/4" MDF with a 3/4" red oak edge trim.
