The workshop is slowly taking shape. Just my main work table to construct, it will be 36"x 73" and sit end-to-end with my existing table.
I have been waiting on the 44" wide, 13 drawer tool storage from Harbor Freight to go on sell, well this past weekend it did. It will make a great storage unit for the aircraft tools that on my list to purchase. The small parts bin on the wall should work just fine for the thousands of rivets.
I added an air compressor regulator and the retractable hose reel to my compressor set-up to help manage the hose. I also put in a 60amp load center so that when the compressor kicks in it does not trip the main circuit breaker. While I was at it I split the duplex outlets that run around the entire basement area into two separate circuits.
