Their is an extensive amount of internal baffling that directs cooling ram air to where it is needed and prevents it from going where it is not. There are tubes that branch out to direct air air to specific locations and accessories. Many of the edges of this baffling will have seals fitted against the cowling. The baffling is made from light weight aluminium. It is important the cowlings are tight and secure and do not come loose with vibration.
