We had to wait 4 weeks for the adhesive to arrive from America. We closed the cove skin with the necessary rivets and the final part of the installation was to use special adhesive to close the trailing edge. As indicated in image one, the adhesive was applied and then a long straight peice of material was clamped on either side whilst the adhesive set. It only took about 15 minutes for the adhesive to set and the end result was a very clean sharp looking trailing edge beautifully finished. We finally applied one rivet in each corner.
