Brief Description: Fabricate and install the elevator control stop
We took the advice of the instructions and fabricated the elevator control stop whilst we we were putting together the elevator bellcrank. This aluminum sheet is around 4mm thick and getting tricky to cut with our equipment. Hence I went to my old mate Paul Douvos and he organised it to be cut. The result from Paul was outstanding. A far better job than we could ever do and hence a lot more aluminum sheet cutting will be coming Pauls way. Paul is using a band saw to do the cutting which we do not have in our work shop.
