Brief Description: Install vent and fuel line in tanks and pumps.
Each auxilary fuel tank gets three fittings not including the sump drain fittings. Firstly the nylon tubing with connectors is fitted. The fuel tank tanks must be vented to the outside air to ensure proper fuel flow. Each vent line runs from the vent line boss near the top of the tank to the wingtip. Holes were drilled to thread the air vent between the ribs and rubber grommets inserted to prevent rubbing.
