Brief Description: Trim, position and drill elevator bellcrank bracke
Pitch control is transmitted from the control sticks via cable to a bellcrank mounted between two aluminium angles bolted to Bulkhead C. A rigid pushrods runs from the bellcrank aft to elevator.
Note: We updated the elevator bellcrank assembly with the new version. Glassair sent us a replacement version as an upgrade in Decemeber 2007. We installed the new version at this time.
