This is the very first thing we had to fit. It felt very good as it seemed we were starting to assemble something. Took longer then planed. This 10 minute job took an hour as we had alll sorts of problems lining uo the right hand wing pivot with bolts. Originally we thought the brackets were not lined up correctly however eventually we discovered the bush on the top was a little crooked and this prevented the bolt lining up.
