Brief Description: Installed FWD Cross Tie Box Bolts
Finished up plans sheet F21 by installing the AN3-7A bolts in through the fwd upper longerons, splices, and into the cross tie box. The plans call for -7 lenght bolts, but I had to put two washers under the nut. I could have used -6a bolts, but I will need to use the kit bolts on another installation later.
