Brief Description: Finished Deburring Aft Fuselage and Parts
Operation debur is now complete for the aft fusealge and its components. I also had to trim down the left and right sides of the Y tail service bulletin doubler due to clearance issues with the tail post rivets. I trimmed off about 1/16" from both sides. Once everything it primed, my plan is to install the y tail strucrture without the doubler first, then rivet the tail post channel and go back on with the doubler. This sequence should give me the clearance to pull the rivets on the tail post while still being able to install the doubler.
