Brief Description: Installed Brackets for Master Cylinder
Well for anyone that has been following my build over the past year, I'm finally back to posting items to my log. I orginally had a problem in August/September when the computer's system board went bad. I replaced it with a Windows 8 machine and had trouble getting Kitlog reinstalled. Kit Log Tech Support (Matt) was excellent and on top of my email. Matt sent me the exact directions to migrate everything over. After than event, I did the Windows 8.1 update. Then Kitlog wounldn't even open. After a while of not having my log, I emailed Matt today and he again sent me the exact info and directions I needed to fix the problem. Turns out that the 8.1 update corrupts the .NET framework. So you have to do a framework cleanup and reinstall. Once that is done you can reinstall/run kitlog. A big thanks to Matt at Kitlog Support for helping me get back up and running!
Tongiht, I installed the bolts and rivets for the cylinder brackets, fabricated the brake handle and bent it for good operator placement. I decided to leave both the flap and brake handles unpainted since they will be getting knocked around a lot and will be scraping against the flap/brake detent assembly. I didn't want the paint coming off and looking ugly. Now I'll just have to clean it from time to time because the bare aluminum gets dirty easily.
