Brief Description: Finished Fitting and Began Drilling Motor Mount
After I decided that all the shims were going to work I had to massively trim the lower airframe motor mount fittings because they interfered with the landing gear spring mount part of the motor mount. This is called out in the plans, but plan on removing more than the plans illustrate.
