Brief Description: Fitted, Drilled and Riveted Hinge Halves to Seat S
Okay, so I'm making up for not being able to post updates on my project since Labor Day. My computer system board went out and I've not been able to make entries to Kit Log before today. I purcahsed a new computer and was able to salvage my hard drive from the old one. I did download Kit Log to the new computer but had trouble finding the database files for everything I had already has logged. After emailing tech support, I'm finally back up and running. I did keep track of eveything I've done over the past four weeks so the logs are now updated.
Tonight I fitted and drilled the hinge halves to the seat sling. I decided to save a little weight and not prime the seat sling or hing halves. This entire assembly can come out, so it would be easy to replace it IF it ever starts to produce corrosion.
