Eric Seber - Waiex Project
Date:  8-23-2013
Number of Hours:  1.75
Manual Reference:  WIX-F09
Brief Description:  Pilot Drilled CTR Channels, Gussets, & Idler Assy.
I fitted and pilot drilled the center channels and remaining gussets for the lower seat area of the forward fuselage. I also pilot drilled the idler assembly and trim spring cable mount. I used my 90 degree drill motor to access most of the pilot locations in the seat area. I don't know how you would drill most of these holes without a 90 motor!
Center Channels & Gussets Pilot Drilled
Idler Assy. and Trim Spring Mount
