Brief Description: Made Idler Assembly Spacer Block and Assembled
After refitting my bandsaw blade (it came loose and partially spun off the upper wheel) I cut the idler assembly spacer block and matched the holes to the vertical bracket. I then reamed the holes to fit the angle brackets and test bolted them together.
